RCU Forums - View Single Post - Prop failures
Old 12-17-2011 | 07:41 PM
R_G's Avatar
R_G
Default RE: Prop failures
ORIGINAL: viva_peru
Hello,
Looking at the blades it seems that in both instances, the same blade failed. This would seem a little unusual. Out of curiosity, do you know which blade you hold on to while tightening the prop nut? The reason why I ask this is that I noticed some crazing on my APC-E props (which are pretty thin) and it always seemed to be the same blade regardless of prop. Then I realized that the blade showing the damage was the one which I normally hold while tightening the nut. I am much more careful when I tighten the nut now and the problem seems to have goen away. I must have been lucky since I have never had a blade fail.
Teo
That's a very good point!
RG
