ORIGINAL: skylarkmk1
If you have retracts, is the CG measured with them extended or retracted?
You do it with the retracts retracted since that should be your normal flying mode. Depending on the model, with the retracts extended you will move the CG a slight amount forward which is ok for landing/takeoff.
Bruce
