RCU Forums - View Single Post - Prop failures
Old 12-18-2011 | 07:27 AM
jmb52760
Default RE: Prop failures
ORIGINAL: rgburrill
I quite using Master Airscrew some time ago on high performance engines just because I had seen too many problems like yours. I see two problems here: first, you are using too small a prop for those engines - you must really like to hear a high pitched whine. Second, the GF prop is designed to give more thrust at low to mid RPM and will twist too much at high RPM. If you want to stay with Master Airscrew then go for the higher performance props. But on those engines you should use APC and increase the size to a 12x8.
When all else fails RTFM.
Here's what TFM says.
I went down a size (and increased the pitch from the suggested 12-7) due to ground clearance issues on the D-40. I don't have enough clearance in the grass for a 12 inch prop. I have no such excuse for the Curare.
I see no warnings or information on MAs site about using that prop on a .60. It says: "Acclaimed Sport Props. Made of Glass-filled Nylon for strength & durability"
I'm not saying that what I did is right, just showing how I got here.
ID:	1701623   Click image for larger version
