How to get inverted 4 stroke to run.
Check you tank center line to your carb center line. They can be a bit off but not a lot. I've got a satio 100 mounted inverted in my ucando .46 with NO PROBLEMS. It idles and transitions all day long just perfect. My bet is your centerline is way off. If you cannot change it, then get a regulator.
Neo
