RCU Forums - View Single Post - Prop failures
Old 12-18-2011 | 01:19 PM
  #47
DougB1
Default RE: Prop failures
ORIGINAL: jgg215
I've seen a lot of painted APC props. Not sure what was used but any fuel proof enamel should work. Black or white with contrasting tips looks much better than gray. Have to admit it improves the appearance a lot. But I would much rather have the performance than pretty though. The contasting tips are important though as the props disappear when turning.
John
I use Krylon when I paint my props, it holds up well to all fuels but you do need to let it set for a couple of days to cure and then re-check the balance.
