RCU Forums - View Single Post - Screws
Thread: Screws
Old 12-18-2011 | 04:08 PM
proanti1's Avatar
proanti1
Default RE: Screws
ORIGINAL: The Mad Modder
ORIGINAL: Dr. Blockhed
I've been doing some work on my buggy and the stock screws seem to strip way too easy. What type of screws are the most durable? I don't race so weight isn't a huge issue.
Thanks <br type=''_moz'' />
The strongest screws are steel ones made with a good steel. Screws with hex socket heads tend to strip much less than regular phillips ones. That said, I use a lot of Dubro's socket screws. Since Dubro doesn't make button head screws, I use Axial ones when I need button heads. As far as phillips screws go, I do use Tamiya's when I have them because their screws are very good. They rarely strip out on me.
Dubro does make button head screws, but they are only for sheet metal/wood unfortunately. I too suggest Dubro, they market a quality fastener, built to high standards.
More often than not, screws strip because of low quality tools. The 'L' shaped allen keys are generally really only meant for emergency repairs, this is why they are included with kits. If you know you will be doing any sort of extensive maintenance on your cars, you'll need to invest in a decent set of allen drivers, ones that are meant for small screws. Those budget sets of allen keys are not really made to high tolerances, so you end up with a loose fit, which in tun, strips screws. HK sells some pretty affordable driver sets. My personal favorite is Hudy (X-Ray), they are expensive, but really really high quality.
