RE: Jr Falcon Build
It's water under the bridge for you now, but I think the laminated leading edge technique doesn't add much - other than weight.
Notched leading and trailing edges do make for easy jigging and straight building though.
I think the best strength/weight/jigging compromise would be to cut shallow notches about 1/32" deep in solid stock, and make substantial glue fillets.
