RCU Forums - View Single Post - Emergency Shut Down - Important info.
Old 12-19-2011 | 02:34 AM
BaldEagel's Avatar
BaldEagel
Default RE: Emergency Shut Down - Important info.
Jack
Not trying to be a smart a**e, but why would you want to shut down the turbine with the gear up? I use a throttle up on my full vectored thrust Rookie, I consider it almost esential with some of the silly positions I get it into LOL, In a tail slide the air going backwards into the turbine at normal low throttle has I think caused a compressor stall and shut down of the turbine until I put in the idle up, there is a mix for this on the 12FGA.
Mike
