RCU Forums - View Single Post - Emergency Shut Down - Important info.
Old 12-19-2011 | 09:47 AM
BaldEagel's Avatar
BaldEagel
Default RE: Emergency Shut Down - Important info.
ORIGINAL: Jack Diaz
Mike, could you tell me how the ''throttle down '' works?
I may emulate the program in my radio.
I use two different throttle curves, switched by the gear.
Jack
Be careful if you do this, if the throttle curve is taken above the learnt parameters of the ECU the turbine will shut down, that was my second dead stick landing with the Elan, than one was not so cleaver.
One other useful programme in the Futaba Tx's is the trim travel function being reduced in time, instead of 10 clicks on either side of neutral you can set it to 4 clicks, but still with the same amount of travel, this makes trim travel from one end to the other very fast.
Mike
