RE: Finally getting a trailer....need some advice
A trailer has been designed to support a much larger weight than our little airplanes- even the biggest ones. If you want the thing to ride nice you will have to provide some of the weight. A couple of water tanks in the right place can help quite a bit. Then you can always use some water when you get to the field even if you just want to wash your hands.
