ORIGINAL: Popriv
ORIGINAL: billd76
yep same as mine. I did see the pre drilled holes, but drilled my own and staggered them. Be sure to use more than just CA on the servo trays when mounting them. I'm using Hitec HS-485 HB's servo's for all but the throttle. They are ball bearing Karbonite gear with 66 oz of torque. I also added two washers under the forward two holes of the engine to give a tad of right thrust, not sure it really matters, but just thought a little right thrust would be a good thing. I placed a 1100 LiFe battery in between the the servos on the left wing. I didn't realize the the pull pull wires would be so close to the switch where I mounted it. It will be fine where it is, but had I realized it I would've mounted the switch more towards the outside of the wing instead of where I did. The instructions called for mounting the fuel tank in the wing as well, I decided to mount mine extrenal. I like the ease of being able to access everything with the profiles. Makes the engines easy to tune, and fix fuel lines, etc... I set my CG at 4.5 inches. The manual says 4.0 - 5.25! Will have to see how it flies and adjust as needed. The 55 AX should get this thing airborne in less than 10 feet!!
Billd76, thanks for the pics. Did you get to maiden it yet? servo trays came out a little high.. the servos just touch the hatch cover..
I put the tank in the wing, I'll probably regret it later but I wanted the clean look... If it gives me trouble I'll strap another tank on the outside of the fuse and remove the tank in the wing later. ( will have to remove servo tray...)
steve
No no maiden, only broke in the engine. I was tempted.
Also if you see in the pics where I placed the battery switch, it's just under one of the pull pull wires. I'm not happy with that, so I'm going to move it in between the servo wire it's under and the aileron control rod. I'm worried that the wire might catch the switch and turn it off in flight. probably "far fetched" but will feel more comfortable about the maiden with it moved. I'm off of work from the 23rd to the second, so will definitely get her flying soon! Along with whatever else Santa brings me!!
. i was a little high with one of my servos too, I took an exacto knife and very gently trimmed out the cover so it would fit. Well, got to head for Philly Airport and pick up the youngest Marine of the family. What CG are you going to start wit? 55 AX ran perfect during the break in runs. Lots of POWER!! should punch holes in the sky easily!!
