RCU Forums - View Single Post - Top Flite Staggerwing
Old 12-20-2011 | 06:42 AM
  #1700
sbrackets's Avatar
sbrackets
Default RE: Top Flite Staggerwing
Not sure about the plane being nose heavy right yet. Because I measured the C.G at 5.5" back from the leading edge of the fiberglass fairing edge at the wing joint where the balsa wing joins the fuselage. And the plane sat level on the (Great planes)balancer device. I added 15oz. of lead to the nose.
The only thing that makes me think that it is nose heavy is that 3/4" up elevator was marginal for take off and did not leave me with a good feeling for landing. I was thinking the whole time during my flight that I wasn't going to have enough elevator to pull out of a steep decent on a landing approach.
Once airborn the plane needed a lot of up elevator to fly straight and level. I did manage to trim her out for level flight but noticed after landing that my elevator with the transmitter stick in the neutral position, the elevator was now is sitting with about 2-3 degrees of up elevator. So thats how she is flying at straight and level flight.
Does this sound like it's nose heavy to you all? I guess it is, but she balances out perfect straight at 5.5" C.G. You got me!
I know a way to find out if she is nose heavy is to fly upside down to see how the nose reacts then. But on the maiden flight I was just trying to keep her in the air and trim her out, Not doing anything nothing fancy.
Jim
