RCU Forums - View Single Post - Top Flite Staggerwing
Old 12-20-2011 | 06:58 AM
  #1702
Staggerflyer's Avatar
Staggerflyer
Default RE: Top Flite Staggerwing
Double check your thrust line on the engine. If you added any downthrust beyond what the firewall already has built in, it will do this, also.
I agree, though, it sounds nose heavy, by quite a bit.
Since you are in the ballpark now, tho', you can start removing the nose weight, a small amount at a time, till it flies like you want. On mine, the elevator is nuetral, and it is not pitch sensetive.
Don
