RE: Balsa USA 1/4 Sopwith Pup build
Hi Ewan, if you want to post pics don't use the fast reply at the bottom of the screen, use the reply button in the top right of the post window, there is a reply, quote, fwd and a yellow circle there.
(When you are reading this it will be in the top right of this box)
Once you are in the bigger reply window, at the bottom is two options, use the "click here to upload images and files"
Also don't try to post pics that are too large, you can open up pics in paint and resize them down to 200kb or so.
Regards Mark
PS I'm starting the fuse now.
I have a dremel under the tree that will come in handy, woohoo
