RCU Forums - View Single Post - Banshee
Thread: Banshee
Old 12-21-2011 | 07:45 AM
  #54
MTK
Default RE: Banshee
ORIGINAL: DougC1
I’m to the point that a decision needs to be made regarding paint. I’m leaning towards Nelson Hobbies paint, as it’s claimed to be brushable, and I might be able to use it in the basement with minimal ventilation. I’m open to other ideas or comments regarding Nelsons’ from others’ experiences.
Thought I’d make certain that I knew where all the pieces were, so she got assembled for a photo shoot. The wing needs a few more coats, and then should be ready for primer. The total weight gain of the wing to this point is (130 grams) 4.6 oz. As pictured below, the total weight is 5# 12.5oz (need to add the remainder of the glass to the fuselage, paint, four servos, receiver, battery, and tank). I’m feeling fairly comfortable about hitting 7.5# or less auw.
Thanks for checking in.
Doug
If you want to brush water based paints, don't overlook Testors acrylic paints. They are intended for model cars but will work fine for planes too. You will likely need to spray a clear coat to better protect the acrylic after everything dries.
I have found the paint to flow out reasonably well as brushed. Their gloss is best described as satin finish and their flat is truly flat. Coverage is very good with minimal effort.
The 5# 12 oz weight is for plane only? No hardware? Or are you including engine and retracts? Hopefully it includes engine and retracts.
