RCU Forums - View Single Post - 1st pull pull setup?
Old 12-21-2011 | 08:58 AM
  #33
Popriv
Default RE: 1st pull pull setup?
Billd76, I'm off work next week also so I'm hoping for weather at least in the mid 40's so I can maiden this thing... I mounted my switch so it is on top of the wing when upright. I dont have to flip plane over to turn on/off.... My OS. 55 was bought used a few years ago and is well worn in.... Runs great.
I'm thinking a 12-4 prop? slow it down and get more pull... I screwed up my rudder pull pull, late nite of building I should have gone to bed... I looped the wire directly to the control horn on the rudder.. On the outer most hole. I guess its ok that way I just cant move it to another hole if needed. I'll leave it that way and only redo if I find I have to move to an inner hole on the rudder... I'll do better on the elevator tonight...
IS IT CRAZY TO MOUNT THE ENGINE WITH SCREWS? they would be going into a hard wood block... Or should I just use bolts?
Gettin close, I can taste it.....
steve
