Landing with a moved back CG
I could land my dazzler very slowly with relatively high nose approach.
i move the cg back (as far as the manual allows) and since then the same landing approach causes the model to stall.
in this case i have to use more engine power or to land much more flatted.
does moving the CG back causes the increase of the stall speed or there is other explanation ?
thanks
