RCU Forums - View Single Post - Glodberg Eagle flight problems
Old 08-26-2003 | 10:41 AM
ysrcflyer's Avatar
ysrcflyer
Default Glodberg Eagle flight problems
I shimmed the front of the wing and I needed almost 5/16" of shims to get both at "0". Then the wing doesn't sit very secure on the saddle. Does any one have a copy of the plans for this so you can check what it originally should have been? To me its hard to understand how it could have been built this far off. If this is the case it looks like a winter rebuild project. Also if I shim up the wing, what happens to the engine and fuselage thrust angles?
