RCU Forums - View Single Post - Glodberg Eagle flight problems
Old 08-26-2003 | 11:06 AM
rogwabbit
Default Glodberg Eagle flight problems
Re: Also if I shim up the wing, what happens to the engine and fuselage thrust angles?
I wouldn't worry about that too much.. you will be changing the aoa on both surfaces.. mostly it will cause a little more drag during flight. This may be good for learning anyways as it will slow it down a little.
If you are really concerned, shim the bottom of the motor mount to give a little up thrust.
