RCU Forums - View Single Post - Best engine for Twist V2?
Old 12-22-2011 | 07:02 PM
Pylonracr's Avatar
Pylonracr
Default RE: Best engine for Twist V2?
ORIGINAL: JT Hammer
A Twist is what it is. It is not a pattern bird for sure, and it probably isn't the greatest 3-D flyer. But I think it may be a good everyday knockaround fun flyer, and I think it will hover ok (from what folks are saying). That's all I want! I think the .55 ax sounds like a good match pylonracr. By the way, how do you get the Twist or any other bird to do an inverted climbing flat spin!!!
JT
Easy, actually it is easier than inan upright spin. From a vertical line, slow with power on and perform an inverted snap roll(Down elevator)and hold. The plane will fall into an inverted spin, go to opposite aileron to flatten the spin. My Twist likes to fall out of any spin if I use too much rudder or elevator. I have my low rates set for spins so I can use full stick. Play around with your control throws and you will find thisplane loves to spin. If you have enough power and the right prop, you can gain altitude in a flat spin. Enter the spin at about half throttle or so, and whenyou are in a stable flat spin addthe rest of the power. The Ax55 is enough, play with a few props and have fun.
