RE: Jr Falcon Build
O.K., tonight's update does not include pictures. Everything is clamped, blocked or weighted. I shaped the wing tips and joined the two halves. Installed nose gear and sheeted some of the fuse. Need to leave some off so I can get the push rods in. Also glued vertical stab into horizontal one and drilled holes for hinges in rudder. Will use figure 8 method. Very free for a 1/2 A. I will take a couple of pictures tomorrow. Can't decide if I want to use rubber bands or bolts.
John
