RE: Sig Rascal 110
PTS,
The ID of the cowl in the middle is 5".
bladebender,
There is no mention of electric setup in the manual or the manual update.
JeffinTD,
Since all the control surfaces are pre-installed and glued your stuck with what you get. If I could have glued the hinges in myself I would have set the control surface out a little futher to gain a little more throw. From experience with my last Rascal 110 you need all the throw you can get if you want to fly a little 3D. There is no hatch in the fuse.
