Trimming a new airplane
next ? personally I would also balance the model laterally by adding weight to the wing tip on the lighter side. A laterally balanced model will be a lot easier to trim.
Then I would work on the engine thrust angle, have a look on the net for a trimming chart which will give you the info you need.
Chris
