RCU Forums - View Single Post - Flywheel center as part of a prop hub.
Old 12-23-2011 | 06:51 AM
gr8flyer55
Default RE: Flywheel center as part of a prop hub.
Reproducing the tapered shaft and mounting the flywheel to it is probably my best option in this case. I will post a picture or two today of the flywheel so you can see why I want to preserve as much of the center as possible. In my opinion, it will give plenty of support and provide a mounting method. Resembling the largish prop driver from a Supertiger. This is the end result I want to accomplish. It has two webs inside of it which can be drilled for the magnet, or I can do the outer diameter like all commercially made hubs. I hope this works. I have a semi scale rough drawing of what I want it to look like which I will post also.
John
