RCU Forums - View Single Post - Flywheel center as part of a prop hub.
Old 12-23-2011 | 11:41 AM
av8tor1977's Avatar
av8tor1977
Default RE: Flywheel center as part of a prop hub.
I have done this numerous times and it works fine. I usually just cut the center out with a hole saw in the drill press however, and then true the center piece up in the lathe.
AV8TOR
