RCU Forums - View Single Post - Flywheel center as part of a prop hub.
Old 12-23-2011 | 12:59 PM
Nosedragger
Default RE: Flywheel center as part of a prop hub.
If you can reproduce the shaft,then you can make the hub you need, why go through all the other work?
