RE: Jr Falcon Build
Lot's of progress over the last couple of days. All the sheeting and rough sanding on fuse is done. Elevator done and rudder needs to be attached. Landing gear installed. Pushrods done. Stab needs to mounted and aligned. Wing needs to be glassed and aligned. Opted for rubberband hold down for wing. Think i'm going to cover stab in silk, wing in poly span and fuse in silk span. Never used the poly span before and hear it doesn't like tight curves, hence using silk on stab. If Xmas doesn't get in the way, may start covering tomorrow. Needs a couple of coats of dope first and the Little Lady does not like me to smell the house up. [&o] First picture was before sanding and the other 2 are sanded and the elevator being assembled. Stay tuned.
John
