RCU Forums - View Single Post - Flywheel center as part of a prop hub.
Old 12-24-2011 | 10:08 AM
Scota4570
Default RE: Flywheel center as part of a prop hub.
Maybe I'm not understanding the question. If so disregard.
Make a prop hub and the nut that retains the flywheel the same piece, like a G-38. You will need a lathe to do this kind of work. Otherwise it will never be in balance, except by luck.
