RCU Forums - View Single Post - Silver Swallow Pulldown
Old 12-24-2011 | 03:30 PM
  #61
123Cat
Default RE: Silver Swallow Pulldown
Got a Camera
Here is a picture
I will look up the expansion of steel and Cast Iron
My next step before I fly it will be to machine the crankcase a bit truer and lighten the rod up near the piston pin as its too thick , I might check the inlet timing and see if I can make it similar to the Fora Junior timing , Make an exhaust collector ring, grind some weight off the top of the cylinder Machine down the spraybar to get a bit more airflow , Smaller prop as the piston is quite light, it will rev
Its not as lively as my first Silver Swallow 1.75 cc engine , it needs a stroker crank with lots of weights in to match that one
