RCU Forums - View Single Post - VSTank airsoft spring upgrade
Old 12-25-2011 | 11:56 AM
shenlonco's Avatar
shenlonco
Default RE: VSTank airsoft spring upgrade
Hi and Merry Chrismas!
Use only airsoft gun silicone spray lube.
and a spring you may not need one first try putting a little spacer behind the original spring not on the plunger side on the side where the spring hits the casing this will make the stock spring compress more for a little more punch.
