sd-10g 2 servos per aileron surface c-mix does not work right past 100% throw
SD-10G When i set up the flap and aileron mixing everything is fine until i need to push the control surface to max deflection 150% (needed for 3D). When i set the aileron to 150% under SURFACES and then go to C-mix to set end points on the flap i can get it to max end point but it does not move in tandom with the aileron servo. Once at max deflection when i start to back it off the aileron servos moves as soon as the sticks moves but the flap servo does not move until i get to about the 100% point.. I tried mixing other channels and they all do the same thing. HELP Is this a clitch?
So to get my four aileron servos to work i set the sd10 to glide but and got the throttle to stick on 1 but have no trim funtion on stick 1 now. WHATTODO..
oh this is a 37% 120cc bird.
