Easy lines & rivets
This subject has been discussed several times in several threads, but the question keeps comming up, how do you make pannel lines and rivets ?. I have played around with this myself and hears what I came up with. Scribed lines and rivets how to do.
The first thing you have to do is prepare the surface and this is important because it will dictate the out come. Prior to the final priming ( asuming it's getting painted ) the surface must be cleaned with a laquer/enamel prep solvent useing micro fiber towels. Just dampen the towel don't soak it and clean it until you don't see any more dust on cloth. As soon as it dries it's ready to primer. I use Dupli-Color laquer but enamel will do also. I let it cure a whole week in heated shop before I do anything else. Get the primer on as uniform as possible, the thickness is what you have to scribe on. You may want to sand it very lightly with 6 to 9 hundred grit paper with 1/4 foam between paper and block. wipe it down ( I use a fine hair round brush on vacume hose to remove most of the dust first ) you'll use the solvent again after detail is put in.
Tools needed are scribes, carbide straight, ( Lowe's ) and dental picks ( they make the beat scribes ) They are so hard if you try straighten one out it will break off but once it's sharpened it will stay sharp. Go to your dentist, they just throw them away. Rulers, the thinner the better and if they don't have cork backing you can spray them with contact cement and when it dries it's not sticky. Now your rulers won't slide around, we don't want a slip at this time. Styrene clear sheets to make rivet patterns, fuel tank and hatch handels and so on. !/6"and 1/8" brass tube.
Lay out the pannel lines by very lightly marking with a # 2 pencil, don't mark any interior lines until all pannels are scribed. Fine line between pannels and a little bolder line where hatches are, it gives them more depth. Your not going deeper, just broader, remember, primer thickness is all you have to work with. I should add at this time, you should have made a test pannel finished the same way the plane is preped so you have something to test on and get a feel for it
Making the rivet guide. Useing the styrene ( sheets are 2-8"X10" and are .030" thick ) cut a strip 3/4" wide and lightly score a line down the middle, 3/8" to center ( your going to need a drill press for next step) Make a jig of sorts to slide the strip down and drill uniform holes the length of strip just off center of scribed mark. When you drill first hole draw a line 3/16-1/4" from center hole in guide/jig and center each drilled hole on that mark all the way down for uniform holes. If center mark is dead on just turn strip around, not over and drill other side useing same mark for perfect aligned rivets. 3/32" bit for 1/4 scale and 5/64" for 1/5 scale. This is Page one See page two.
