RE: ESM Mitsubishi J2M3 Raiden build
Got my powerplant today. It's a Zenoah G-62 with an electronic ignition. I bought a longer prop hub (2 3/16th) but it still is not quite long enough to hide everything.
As it is now my options are to either open up a hole next to the scoop on the cowl for the plug boot or to slightly rotate the engine a few degrees so that the plug boot sits in the scoop.
The only downside to rotating the motor a few degrees is that the exhaust stacks will be slightly further up the cowl.
Does anyone have a source for a slightly longer prop hub?
