RCU Forums - View Single Post - How the "level" the playing field?!
Old 12-27-2011 | 07:32 PM
  #66
MTK
Default RE: How the
ORIGINAL: cmoulder
Sounds like mine... about 6 deg el, 15 rudder, 22 ail and very little expo, or thereabouts. Quick as I can put the sticks in the corners and get them back with the Spark usually gets it done.
Won't know for sure until next Spring, however.
6 degrees of elevator? That doesn't sound like enough to show a rapid pitch departure. Is the Spark a good enough plane design to actually pitch load the wing and then autorotate with 6 degrees?
To speedracer, the things top judges look for in snaps are very quick pitch followed with yaw and roll, and then a clean exit. Often the model displaces in pitch and yaw when a better snap is performed. I don't downgrade for slight displacement of about 1/2 to 1 wingspan. The speed of a snap is not a judging criterion, but unfortunately some folks mistakenly think that the faster one rolls the crate the better. These types tend to score better on average. That's the major reason wings on present pattern models have gotten as small as they have, to make the model turn into itself in the blink of an eye.
Personally, I prefer a slower snap, one which allows a little more time to see what happening. It is a matter of set-up
