RCU Forums - View Single Post - Easy lines & rivets
Old 12-28-2011 | 09:57 AM
Leroy Gardner
Default RE: Easy lines & rivets
I'll try the pictures again. SO where the H- are picts?. "Oh yes"'
The pictures don't do justice to how they really look but will give you an idea what can be done scribing details. There are tools used, and the paint for this test is Dupli-Color from spray can. I sprayed full wet coats on half of test and 3 fogged coats on other half and it never made any difference to appearance of detail. You can see the size difference of rivets useing the two different cut tube scribes. the sharper the tubes the better they look. I'll fine tune my scribes to get better pannel lines, this is just a test to see what works best. The hinge really looks like a hinge, I was impressed with how real it looked, the fine cut lines are 2/32" apart with segmented cuts every 5/16". Most hatches that open have hinges like gun and ammo bays.
Styrene sheets are easy to cut with razor sharp blades and drills and make great patterns to scribe with, you can go as far as you want detailing your plane. When it's all done don't forget to wipe it down with prep-sol to remove dust and finger prints prior to paint, and keep your hands clean!.[&o]
I'll check back from time to time and answer questions. My question is, when you can do this, why would you want to burn them? Leroy[8D]
ID:	1705970   Click image for larger version
ID:	1705971   Click image for larger version
ID:	1705972   Click image for larger version
ID:	1705973   Click image for larger version
ID:	1705974   Click image for larger version
