RCU Forums - View Single Post - Easy lines & rivets
Old 12-29-2011 | 05:38 AM
Dash7ATP's Avatar
Dash7ATP
Default RE: Easy lines & rivets
<span style="font-size: small">Leroy,
That system certainly seems to give very nice results. I have considered using the scribe several times. In fact,Ihave used it to add a line where Ihad forgotten the 1/64 tape. My only problem with that was either having the guide slip or my tool didn't follow the guide.l AS for your rivits, I'm not sure just using pressure with your cutting tools would do the job on an epoxy primer, which is all I use since I'm still using glow engines.
If you want to really make you work stand out, give this a try. Go to an artist supply store and get some of the small tubes of acrilic paint they use. It's water based and cheap. For a silver plane, I'd use a dark grey. Other colors just need some contrast. A light grey would probably work best on the reds and blues in the stars and black numbers. Put a dab on a piece of plastic or vinyl and thin it slightly with water. Smear it all over the area you want to weather and let it dry. Then using a dampened towel or paper towel, wipe it off in the direction of the airflow. Some of it will remain in the rivits and panel lines and leave light streaks. Since it is water soluable, you can remove as little or as much as you want.
Try that on your test panel.
Dash</span>
