ORIGINAL: Howard
Zippi,
I understand from your choice of engines that you prefer more power than the G26ei however, can you give me your thoughts on how well a G26ei would do based on your experience with the G26? I am also waiting on a blue Rascal that is due sometime in Feb. Thanks
Howard
You will not be disappointed with the g26ie. I ran a bambula 18-8 prop. I also had a Ralph Cunningham aftermarket ignition unit which draws much less current. I could not hover but knife edges and rapid climbed were a blast.
