RCU Forums - View Single Post - Valley View Rc profile yak
Old 12-29-2011 | 08:27 AM
MetallicaJunkie's Avatar
MetallicaJunkie
Default RE: Valley View Rc profile yak
ORIGINAL: billd76
ORIGINAL: MetallicaJunkie
yes i added longer arms on the ailerons but they really arent needed... and i used 1.5'' servo arm elev and i can get over 40 deg in any direction, and 1.25 for rudder
i used 5925(old hi speed hitecs) and 5625 on elev and rudder and a 625 on throttle...
for the maiden flight.......with the wings and hatch on i CGd it right on the wing tube.. i got some kite string and made a quick cradle
im happy to help
ok another question. Where did you mount your throttle servo? and did you use a rod or wire for the throttle.
i mounted it behind the tank.... i used 440 all thread rod cut to size and a flex rod tube to eliminate friction.... if you need a pic lemme know, i can do that
