RCU Forums - View Single Post - Easy lines & rivets
Old 12-29-2011 | 12:08 PM
Leroy Gardner
Default RE: Easy lines & rivets
Hi Dash, thanks for reply. Yea, I don't know how this would work on epoxy. it's pretty hard stuff. I use laquer for two reasons, 1 it's the lightest of all paints and 2 you can top coat it with most any paint, well now 3 you can scribe it and get a very realistic look and thats what I want. You might try laquer some time and you won't go back to epoxy, unless your going to do flight-metal over it, thats what they call for. One thing I found out is how fine a scribe showes up, different colors will show differently but the scribe still comes through. Aerosol sprays are the best paints because they are so light and fine whereas heavyer bodied paints will have a more filling effect on fine details and will require a bolder scribe. When I started out I was'nt sure how much painting would effect the scribes so I used both light and heavy pressure cutting scribes and was surprised and pleased at the outcome. Now it's a case of practice makes perfect.
First pictures I posted I wasnt happy with, they were taken under shop lights so I took another set out side in natural light, shade and sun,"wow" what a difference. Silver is very reflective and details really show up. Like I said this is a test piece just to see how it comes out and now I'm sure I can do a uniform job on the plane. I'm starting to get a little excited about finishing this bird, it's been a long time coming. Hand and shoulder surgery has held this up for nearly two years but all is well now,"thank God". Leroy
ID:	1706510   Click image for larger version
ID:	1706511   Click image for larger version
ID:	1706512   Click image for larger version
ID:	1706513   Click image for larger version
