RCU Forums - View Single Post - HELP
Thread: HELP
Old 12-29-2011 | 07:01 PM
unclecrash's Avatar
unclecrash
Default RE: HELP
Thanks for the link Ron. Those K&O are some pricey devils. See them on ebay in the $300 range and up. Mine is a flex shaft in there the two halfs split below the engine. Im thinking there is a half crank with a hole that ingages into the engine crank then you slide the motor through the first half the bottom end. Then there must be a collet with 2 grub screws to hold it together. Its hard to picture without photo's . I will load some later if I can get a chance.
