RE: Balsa USA 1/4 Sopwith Pup build
Thanks! That is what I was planning but wanted to verify. Will have to move the location of the strut on the bottom wing to make it vertical to the building surface. I also leveled the wings and ensured that they are perfectly parallel, with 0-1% positive incidence. Everything actually came out perfect without the need for any shimming. "Better to be lucky than good."
Thanks!
Kevin
