U-C-DO 46 vs 60
U-CAN-DO .46 tips? (post # 1)
i just bought the u-can-do .46. it is a great plane but there are some problems with there hardware. i have done alot of reading and i mean alot on the u-can-do. and it seems that if you use standard servos such as the futaba 3003 or 3004 you can get ALOT of flutter if you have any slop. but you can stop that if you up grade the hardware. i did not use their push pull rods. i upgraded them to 4-40s. then i put carbon fiber over the 4-40 rods. then instead of normal clamps i put ball links. dont use their control arms they flex way to much and cause a ton of slop. use something else. when you use and install your CA hinges. make sure that there is no gap in between the surfaces and the wings or stab. make sure the CG is in the right.
