Now Minn, you need to stop holding it all in like that, you need to let it out some times. You know it is not good for you
Not sure how he thought a 4s would run backwards? New cam and timing?
A little out thrust will help some. A couple of degrees is all. Just do not try to fly around with one engine out.
I was totally freaked out about my first twin. I had heard the stories of you need to do this and that and most of it came from people who had never flown a twin. I found out after the 5th flight or so, most of the rumors were just that, rumors. Plane did have a bad turn when an engine went out. But it did not go into a death spin or some other crazy stuff you may have heard. Just be ready for rudder inputs.
Buzz.
