RE: sd-10g 2 servos per aileron surface c-mix does not work right past 100% throw
You can certainly do that but then you can't set the centers and epa's independently for the two servos on each surface. If you can get the servos and linkages to match exactly mechanically, then that's great but that's not always possible.
