RCU Forums - View Single Post - Problem with Redcat Shockwave
Old 01-01-2012 | 07:34 PM
codokas
Default RE: Problem with Redcat Shockwave
Plug the end of the fuel line going to the carb and blow gently into the line that goes to the exhaust. If the fuel tank cap is good it should hold some pressure. If it leaks or the top pops up too easily, then the fuel tank is bad.Check your fuel lines for pin holes by taking each one off and submerging it in water, plug one end and blow in the other end and look for bubbles, flip it around and do the other end.
DOUG
ORIGINAL: Reuben-rc
The problem with my Redcat Shockwave is that when you try to prime it fuel doesnt go through the gas line cause there is no air pressure. Also I am kind of new to nitro rc cars but is there supposed to be nitro or some liquid everywere after you run it? I think it might be a leak in the gas tank that is causeing both. Please tell me anything you think that it might be. Thank You!
