RE: P 38 Help 1st Twin
Until you are used to the plane, I suggest this rule: One engine out, all engines, out. If you suspect an engine is out, go to idle and land as safe as you can. ANY abnormal movement must be suspected as an engine out. The plane can go out of control in what seems less than a second when one engine stops.
