RE: sd-10g 2 servos per aileron surface c-mix does not work right past 100% throw
here are the instructions i followed. good luck
John
Select SYSTEM. Press ENTER. Scroll to TYPE (#05). Press ENTER.
Use the Navigation Pad with the YES/+ and NO/- keys to make the following assignments.
Wing >Normal, Ail >2, Flap >2, Tail >2xEL, TH >1. Press the END key.
Scroll down to CHANNEL ASSIGN (#12). Press ENTER.
Using the Navigation Pad with the YES/+ and NO/- keys make the following channel assignments.
01 >LE, 02 >LA, 03 >TH, 04 >RU, 05 >GE, 06 >RA, 07 >RE, 08 >LF, 09 >A1, 10 >RF.
Press the END key.
Scroll down to SWITCH ASSIGN (#13). Press ENTER.
Make the following assignments:
Zero out all AUX channels and Flight Modes. Set the following as indicated.
FLAP 1 >ON>OR -;
C-MIX 1 >ON >OR >-; C-MIX 2 >ON >OR >-; C-MIX 3 >ON >OR >-;
Press END key twice.
Select F-MODE. Press ENTER. Scroll down to C-MIX (#18).
Use Navigation Pad, YES/+ and NO/- keys to make display read:
C-MIX >1 C-MIX >2
COMMON >COM COMMON >COM
MASTER >LA+ MASTER >RA+
SLAVE >LF SLAVE >RF
POINT >1 RATE >–100% POINT >1 RATE >-100%
POINT >9 RATE >+100% POINT >9 RATE >+100%
C-MIX >3
COMMON >COM
MASTER >RU
SLAVE >AUX 1
POINT >9 RATE >+100% Press the END key once.
Scroll Down to VR ASSIGN (#19). Press ENTER. Set as follows:
COMMON >COM
FLAP 1 >-
AUX 1 >-
AUX 2 >-
AUX3 >-
AUX 4 >- Press END key three times.
- 2 –
Select SURFACE MENU. Press ENTER.
Set LF CENTER to –50% and RF CENTER to –50% to neutralize the servos. Press the END key.
Set EPA to +50% for LF and RF. It will indicate 1 50 to show Flap 1 is set at 50%
NOTE: All of the above values are trial values. Fine-tune and set up servo centers, throws, reversing and EPA’s as follows:
Aileron Channels #2 and #6. EPA, Reverse, and Center set in SURFACE Menu.
Elevator Channels #1 and #7, EPA, Reverse, and Center set in SURFACE Menu.
Left Flap and Right Flap Aileron Channels #8 and #10, Reverse and Center set in SURFACE Menu.
Left Flap and Right Flap Aileron Channels #8 and #10 Servo Throws set in C-MIXERS #1 and #2.
Rudder, Channel #9 Servo throw set in C-MIXER #3.
Jack R.
