Correct me if I am wrong. You will need the following for the conversion.
http://www.redcatracingshop.com/product_p/06034.htm
http://www.redcatracingshop.com/Sear...?Search=02023S
http://www.redcatracingshop.com/product_p/02045.htm
The two speed conversion will be a very very nice upgrade for you.
ORIGINAL: runner1514
Great! I was really hoping it was normal and I didn't have to take it apart. Thanks for the reply. I was also considering switching to a two speed transmission. Part number
02045 is the clutch that goes inside the transmission itself? If so, I'm guessing that the clutch comes with the new transmission when you buy it, no? Thanks!
ORIGINAL: Dads like rc too
I just realized that my clutch bell moves back and forth a bit, about 2mm maybe 3mm max (I think). I'm not sure if this is new or not and I ran the car this way yesterday and everything was fine. I have already ran about 3/4 of gallon through the engine and everything is still the original pieces. I guess I was just wondering if that was normal or if the screw that holds the clutch is slowly coming off.
http://s681.photobucket.com/albums/vv178/agustinxc/?action=view¤t=DSCN2539.jpg" target="_blank">[img]<a href=[/img]http://i681.photobucket.com/albums/vv178/agustinxc/th_DSCN2539.jpg" _fcksavedurl=" >http://i681.photobucket.com/albums/vv178/agustinxc/th_DSCN2539.jpg" _fcksavedurl=" >http://i681.photobucket.com/albums/vv178/agustinxc/th_DSCN2539.jpg" border="0" alt="Photobucket" >
http://s681.photobucket.com/albums/vv178/agustinxc/?action=view¤t=DSCN2538.jpg" target="_blank">[img]<a href=[/img]http://i681.photobucket.com/albums/vv178/agustinxc/th_DSCN2538.jpg" _fcksavedurl=" >http://i681.photobucket.com/albums/vv178/agustinxc/th_DSCN2538.jpg" _fcksavedurl=" >http://i681.photobucket.com/albums/vv178/agustinxc/th_DSCN2538.jpg" border="0" alt="Photobucket" >
it looks like the clutch is sliding off the shoes. No this is not normal. It's hard to believe you haven't shredded a spur gear yet. You'll have to remove the engine and tighten the clutch bell screw in the crankshaft. Use blue locktight on it.
