ORIGINAL: MTK
ORIGINAL: Umran
Later if i can find a perfect voltage regulator (which doesn't ripple out the voltage and maintain constant output) even when the battery output is being used for ignition system which is constantly cycled between drained and stop based on engine rpm setting, then perhaps we can use only 1 battery onboard for a gasoline set-up.
At this moment i have not found it yet.
Umran,
You may want to take a look at the Tech Aero voltage regulators and IBECs
Will look at it... thanks.
