RE: hobby zone mini super cub - flys right turn
The advice I'll offer on adjusting it is to go slow. Your rudder trim may move as the thrust line changes, and small fixes are better than big ones for a beginner. Is your rudder set straight when it's trimmed to fly straight with the power off? If it's offset, you may have a wing warp that you're compensating for with rudder trim. That will show up in flight as a plane that flies in a straight path but is pointed a little crooked.
